Join the Repair Community - Create Account
Toshiba Satellite A210 Optical Disc Drive Replacement
Bret Wilson
Bret Wilson and 14 other contributors
Last updated on May 20, 2023
5 - 10 minutes
Easy
Markup Mishap
Introduction
Go to step 1
In this guide, you will learn in a step by step process how to remove an optical drive in your Toshiba Satellite. This guide does require some tool use. Follow each step according to the bullets provided.
Tools
Show more…
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: step 2, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement: step 2, image 2 of 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: step 3, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: step 3, image 2 of 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 1 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 2 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 3 of 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 1 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 2 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 3 of 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Gear Up For Future Repairs
Shop all
Bret Wilson
289 Reputation
1 Guide authored
Cal Poly, Team 17-5, Regan Spring 2013 Member of Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Members
18 Guides authored
1 Guide Comment
Question : if i this will my screen start working ng again
jessica johnson - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 1,755
