Toshiba Satellite A215 S4697 Keyboard Replacement
  1. Toshiba Satellite A215 S4697 Keyboard Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Keyboard Replacement: step 2, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 2, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 2, image 3 of 3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Keyboard Replacement, Optical Drive: step 3, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Optical Drive: step 3, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Optical Drive: step 3, image 3 of 3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  4. Toshiba Satellite A215 S4697 Keyboard Replacement: step 4, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 4, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  5. Toshiba Satellite A215 S4697 Keyboard Replacement: step 5, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 5, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 5, image 3 of 3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  6. Toshiba Satellite A215 S4697 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite A215 S4697 Keyboard Replacement: step 6, image 2 of 2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  7. Toshiba Satellite A215 S4697 Keyboard Replacement: step 7, image 1 of 2 Toshiba Satellite A215 S4697 Keyboard Replacement: step 7, image 2 of 2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  8. Toshiba Satellite A215 S4697 Keyboard Replacement: step 8, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 8, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 8, image 3 of 3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  9. Toshiba Satellite A215 S4697 Keyboard Replacement: step 9, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 9, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 9, image 3 of 3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
  10. Toshiba Satellite A215 S4697 Keyboard Replacement, Keyboard: step 10, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Keyboard: step 10, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement, Keyboard: step 10, image 3 of 3
    • Place laptop right side up on a flat and clean surface. Open the laptop.
    • Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
    • Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
  11. Toshiba Satellite A215 S4697 Keyboard Replacement: step 11, image 1 of 2 Toshiba Satellite A215 S4697 Keyboard Replacement: step 11, image 2 of 2
    • Locate the two 2.3mm Phillips #1 screws at the top of the keyboard that attaches the keyboard to the frame behind it.
    • Remove screws.
  12. Toshiba Satellite A215 S4697 Keyboard Replacement: step 12, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 12, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 12, image 3 of 3
    • Find the latch above the F8 key that overlaps the keyboard.
    • Use a plastic opening tool to press the key board's tab downward, until the key board is released.
  13. Toshiba Satellite A215 S4697 Keyboard Replacement: step 13, image 1 of 2 Toshiba Satellite A215 S4697 Keyboard Replacement: step 13, image 2 of 2
    • Pull the keyboard out by shifting it forward towards the screen and pulling up.
    • CAUTION: Do not pull it out all the way yet. It is still attached to the laptop by a cable.
  14. Toshiba Satellite A215 S4697 Keyboard Replacement: step 14, image 1 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 14, image 2 of 3 Toshiba Satellite A215 S4697 Keyboard Replacement: step 14, image 3 of 3
    Tool used on this step:
    Buy
    • Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
    • Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
    • Pull out the cable and completely remove the keyboard.
5 other people completed this guide.
Joseph Gillum
138 Reputation
1 Guide authored
Cal Poly, Team 4-12, Maness Spring 2013 Member of Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 25
All Time: 2,165
