Toshiba Satellite A215 S4697 RAM Replacement
  1. Toshiba Satellite A215 S4697 RAM Replacement, RAM: step 1, image 1 of 3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: step 1, image 2 of 3 Toshiba Satellite A215 S4697 RAM Replacement, RAM: step 1, image 3 of 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
    • Unscrew the two captive screws with the Phillips #1 and open the compartment.
    • The captive screws cannot be removed from the lid.
  2. Toshiba Satellite A215 S4697 RAM Replacement: step 2, image 1 of 3 Toshiba Satellite A215 S4697 RAM Replacement: step 2, image 2 of 3 Toshiba Satellite A215 S4697 RAM Replacement: step 2, image 3 of 3
    • Pull the two tabs away from the RAM so that the RAM will be removable.
    • Make sure to gently pull the RAM away from the base connections in the device. Do not use excessive force or other tools to remove it.
  3. Toshiba Satellite A215 S4697 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite A215 S4697 RAM Replacement: step 3, image 2 of 2
    • After the old RAM has been removed, insert the new RAM stick and ensure that they are oriented in the correct direction before installation. This can be done by lining up the gold connections to each other.
6 other people completed this guide.
Nikhitha Byragani
58 Reputation
1 Guide authored
Cal Poly, Team 4-12, Maness Spring 2013 Member of Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 Members
18 Guides authored
One Comment
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
wendell burgess - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 2,920
