Toshiba Satellite A215-S4757 Display Screen Replacement
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: step 1, image 1 of 2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: step 2, image 1 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 2, image 2 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 2, image 3 of 3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: step 3, image 1 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 3, image 2 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 3, image 3 of 3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: step 4, image 1 of 2 Toshiba Satellite A215-S4757 Display Screen Replacement: step 4, image 2 of 2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: step 5, image 1 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 5, image 2 of 3 Toshiba Satellite A215-S4757 Display Screen Replacement: step 5, image 3 of 3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Jacob Brown
409 Reputation
3 Guides authored
Texas Tech, Team 12-2, Bennett Fall 2016 Member of Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 380
