Toshiba Satellite A305-S6848 Keyboard Replacement
Joshua E Hong
Joshua E Hong and one other contributor
Last updated on June 3, 2023
15 minutes
Moderate
Introduction
Go to step 1
This guide teaches you how to replace the battery in a Toshiba Satellite A305-S6848 laptop.
Tools
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: step 2, image 1 of 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: step 3, image 1 of 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: step 5, image 1 of 1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: step 6, image 1 of 1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: step 7, image 1 of 2 Toshiba Satellite A305-S6848 Keyboard Replacement: step 7, image 2 of 2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: step 8, image 1 of 2 Toshiba Satellite A305-S6848 Keyboard Replacement: step 8, image 2 of 2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Joshua E Hong
449 Reputation
4 Guides authored
Baylor, Team S8-G1, Johnson Fall 2017 Member of Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 644
