Toshiba Satellite A305-S6848 LCD Screen Replacement
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 2, image 1 of 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 3, image 1 of 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: step 4, image 1 of 2 Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: step 4, image 2 of 2
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 5, image 1 of 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: step 5, image 2 of 2
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 6, image 1 of 1
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 7, image 1 of 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: step 7, image 2 of 2
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 8, image 1 of 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: step 8, image 2 of 2
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 9, image 1 of 1
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 10, image 1 of 2 Toshiba Satellite A305-S6848 LCD Screen Replacement: step 10, image 2 of 2
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: step 11, image 1 of 1
    • Remove cold cathode fluorescent light bulb connector.
Joshua E Hong
449 Reputation
4 Guides authored
Baylor, Team S8-G1, Johnson Fall 2017 Member of Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 550
