You're viewing a previously published version of this guide.  View latest version
Older Newer
Toshiba Satellite A65-S126 Optical Drive Replacement
Geoff Wacker
Geoff Wacker and 5 other contributors
Last updated on November 17, 2022
No estimate
Moderate
Introduction
Go to step 1
This guide provides step by step instructions of how to replace a faulty optical drive.
Tools
  1. Toshiba Satellite A65-S126 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Optical Drive Replacement: step 2, image 1 of 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Optical Drive Replacement, Upper Assembly: step 3, image 1 of 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Optical Drive Replacement: step 4, image 1 of 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Optical Drive Replacement: step 5, image 1 of 2 Toshiba Satellite A65-S126 Optical Drive Replacement: step 5, image 2 of 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Optical Drive Replacement: step 6, image 1 of 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Optical Drive Replacement: step 7, image 1 of 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Optical Drive Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Optical Drive Replacement, Optical Drive: step 9, image 1 of 1
    • Orient the bottom assembly as displayed.
  10. Toshiba Satellite A65-S126 Optical Drive Replacement: step 10, image 1 of 2 Toshiba Satellite A65-S126 Optical Drive Replacement: step 10, image 2 of 2
    • Remove the two 3 mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Optical Drive Replacement: step 11, image 1 of 1
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
Geoff Wacker
91,095 Reputation
89 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 1,032
