Toshiba Satellite A65-S126 Speaker Replacement
Cole Uhland
Cole Uhland and 7 other contributors
Last updated on November 17, 2022
No estimate
Moderate
Introduction
Go to step 1
This is a step by step guide of how to replace the speakers in case of malfunction or upgrade.
Tools
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: step 2, image 1 of 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: step 3, image 1 of 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: step 4, image 1 of 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: step 5, image 1 of 2 Toshiba Satellite A65-S126 Speaker Replacement: step 5, image 2 of 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: step 6, image 1 of 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: step 7, image 1 of 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: step 8, image 1 of 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: step 9, image 1 of 2 Toshiba Satellite A65-S126 Speaker Replacement, Speaker: step 9, image 2 of 2
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: step 10, image 1 of 1
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: step 11, image 1 of 1
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Cole Uhland
216 Reputation
2 Guides authored
Cal Poly, Team 14-8, Forte Fall 2013 Member of Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 581
