Toshiba Satellite A660-ST3NX2X RAM Replacement
  1. Toshiba Satellite A660-ST3NX2X RAM Replacement, Battery: step 1, image 1 of 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 2, image 1 of 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 2, image 2 of 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 3, image 1 of 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 3, image 2 of 3 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 3, image 3 of 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: step 4, image 1 of 2 Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: step 4, image 2 of 2
    • Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
  5. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 5, image 1 of 1
    • Open the hatch that holds the RAM cards.
  6. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 6, image 1 of 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 6, image 2 of 2
    • Pull apart the two metal tabs that are holding the RAM cards in place.
    • You will feel the card pop up from its held position, indicating it can safely be pulled out.
  7. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 7, image 1 of 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 7, image 2 of 2
    • Pull out the top RAM card.
  8. Toshiba Satellite A660-ST3NX2X RAM Replacement: step 8, image 1 of 2 Toshiba Satellite A660-ST3NX2X RAM Replacement: step 8, image 2 of 2
    • Use tabs on the sides of the bottom RAM card to release the RAM card.
    • Remove the bottom RAM card, just as the top RAM card was removed.
Cassie Pickett
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 395
