Toshiba Satellite A665-S5170 Battery Replacement
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: step 2, image 1 of 1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: step 3, image 1 of 3 Toshiba Satellite A665-S5170 Battery Replacement: step 3, image 2 of 3 Toshiba Satellite A665-S5170 Battery Replacement: step 3, image 3 of 3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
2 other people completed this guide.
Chelsea Teague
385 Reputation
2 Guides authored
Baylor, Team 4-5, Williams Fall 2016 Member of Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,163
