Toshiba Satellite A85-S107 15" Disc Drive Replacement
  1. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Battery: step 1, image 1 of 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 2, image 1 of 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 3, image 1 of 2 Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 3, image 2 of 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: step 4, image 1 of 2 Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: step 4, image 2 of 2
    • Flip the laptop over and orient it so that the battery faces away from you.
    • Remove the 5mm Phillips #0 screw on the bottom case.
  5. Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 5, image 1 of 3 Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 5, image 2 of 3 Toshiba Satellite A85-S107 15" Disc Drive Replacement: step 5, image 3 of 3
    • Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
    • Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
Alana
96 Reputation
3 Guides authored
Cal Poly, Team 10-38, Amido Spring 2013 Member of Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 589
