Toshiba Satellite C50-B-14Z Thermal Pad Replacement
  1. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: step 1, image 1 of 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: step 1, image 2 of 2
    • Unscrew the 15 screws holding the back panel in place.
    • Use a prying tool to carefully release all the clips.
  2. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: step 2, image 1 of 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: step 2, image 2 of 2
    • Unscrew the 4 screws holding the CPU heatsink and fan assembly and lift it up, gently.
    • Disconnect the fan.
    • Replace the thermal pad. Be sure to use the same thickness thermal pad.
  3. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Cleaning the fan.: step 3, image 1 of 1
    • Unscrew the 2 tiny screws that hold the fan assembly together.
    • Clean it with a soft brush and compressed air.
  4. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Upgrading the RAM and SSD (Optional): step 4, image 1 of 1
    • Once you opened the back cover, it is a good idea to upgrade the SSD and RAM if you want.
    • This model can take up to 8GB DDR3L.
    • You can also put in a CD/DVD Drive or an additional SSD in its place.
Simeon Brankov
6,448 Reputation
51 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 301
