Toshiba Satellite C55-A5100 Hard Drive Replacement
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: step 2, image 1 of 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: step 4, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C55-A5100 Hard Drive Replacement: step 5, image 2 of 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
0 Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 26
All Time: 1,022
