Toshiba Satellite C55-A5140 CD Drive Replacement
  1. Toshiba Satellite C55-A5140 CD Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure the device is unplugged, completely off, and not warm to the touch.
    • Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
    • Do not handle a deformed battery. Deformed batteries can cause burns and exposure to harmful chemicals.
    • Flip device over and locate two switches on the back of the device.
  2. Toshiba Satellite C55-A5140 CD Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C55-A5140 CD Drive Replacement: step 2, image 2 of 2
    • Slide switch 1 towards the unlock symbol on the device (switch should click into place).
    • Slide switch 2 towards the unlocked symbol on the device.
    • While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
    • Switch 2 does not lock into place and will need to be held in unlocked position.
  3. Toshiba Satellite C55-A5140 CD Drive Replacement: step 3, image 1 of 1
    • Pull battery free from device and release switch 2.
  4. Toshiba Satellite C55-A5140 CD Drive Replacement, CD Drive: step 4, image 1 of 1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Flip the device over so you see the bottom, and loosen the 5mm PH#1 screw on the L shaped access panel.
    • The screw will not come out of access panel, simply unscrew until loose.
  5. Toshiba Satellite C55-A5140 CD Drive Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to open access panel by sliding it into notch near screw and prying access panel(L-shaped) away from device.
    • Pull panel completely free from device and set aside.
  6. Toshiba Satellite C55-A5140 CD Drive Replacement: step 6, image 1 of 1
    • Unscrew the 2mm PH#1 screw next to the Toshiba Device information tag.
  7. Toshiba Satellite C55-A5140 CD Drive Replacement: step 7, image 1 of 3 Toshiba Satellite C55-A5140 CD Drive Replacement: step 7, image 2 of 3 Toshiba Satellite C55-A5140 CD Drive Replacement: step 7, image 3 of 3
    • Using the plastic opening tool, pry the CD drive up.
    • Once the CD drive is partially separated from the device, grasp with your hand and slide it out of the slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 427
