Toshiba Satellite C55-A5140 Keyboard Replacement
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite C55-A5140 Keyboard Replacement: step 2, image 2 of 2
    • Using hands, gently pull keyboard out of device.
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 517
