Toshiba Satellite C55-A5286 Optical Drive Replacement
Nicole Zellers
Nicole Zellers and 2 other contributors
Last updated on July 14, 2023
10 minutes
Moderate
Introduction
Go to step 1
This guide will show you how to remove or replace the optical disc drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
Parts
Tools
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: step 2, image 2 of 2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: step 3, image 1 of 1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: step 4, image 1 of 1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: step 5, image 2 of 2
    • Carefully slide the optical drive out of its place in the laptop.
2 other people completed this guide.
Nicole Zellers
265 Reputation
2 Guides authored
IUPUI, Team S1-G5, Hovde Fall 2018 Member of IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Members
9 Guides authored
One Comment
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 337
