Toshiba Satellite C55-A5300 Battery Replacement
  1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-A5300 Battery Replacement, Battery: step 1, image 3 of 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Battery Replacement: step 2, image 1 of 3 Toshiba Satellite C55-A5300 Battery Replacement: step 2, image 2 of 3 Toshiba Satellite C55-A5300 Battery Replacement: step 2, image 3 of 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 422
