Toshiba Satellite C55-B5200 Fan Replacement
Introduction
Go to step 1A guide on how to replace the fan on your Toshiba Satellite C55-B5200 laptop.
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Tool used on this step:Tweezers$4.99
Remove the single 4.6mm Phillips #0 screw securing the fan.
Use a pair of tweezers to unplug the fan from the motherboard.
Pull the fan out.
