Toshiba Satellite C55-B5200 Keyboard Replacement
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: step 2, image 1 of 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: step 6, image 1 of 3 Toshiba Satellite C55-B5200 Keyboard Replacement: step 6, image 2 of 3 Toshiba Satellite C55-B5200 Keyboard Replacement: step 6, image 3 of 3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: step 7, image 1 of 1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: step 8, image 1 of 2 Toshiba Satellite C55-B5200 Keyboard Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
2 other people completed this guide.
Pablo Andrade
1,081 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Nance Spring 2018 Member of USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Members
22 Guides authored
One Comment
gracias por la guía
Mark Puga - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 35
All Time: 3,862
