Toshiba Satellite C55-B5200 Optical Disk Drive Replacement
  1. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: step 2, image 1 of 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Optical Disk Drive: step 3, image 1 of 1
    • Make sure device is turned off and unplugged
    • Failure to do so could result in electric shock
    • Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
  4. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: step 4, image 1 of 3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: step 4, image 2 of 3 Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: step 4, image 3 of 3
    • Remove the remaining two, 6.6 mm screws to remove the battery
    • Use a plastic opening tool to lift and open the back
  5. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: step 5, image 1 of 1
    • Lift and pull out disk drive
Pablo Andrade
1,081 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Nance Spring 2018 Member of USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 779
