Toshiba Satellite C55-B5200 RAM Replacement
  1. Toshiba Satellite C55-B5200 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 RAM Replacement: step 2, image 1 of 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 RAM Replacement, RAM: step 3, image 1 of 1
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
  4. Toshiba Satellite C55-B5200 RAM Replacement: step 4, image 1 of 1
    • Pull the RAM out of the socket to remove.
3 other people completed this guide.
Pablo Andrade
1,081 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Nance Spring 2018 Member of USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Members
22 Guides authored
One Comment
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
Andrew Kling - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,207
