Toshiba Satellite C55-B5302 CD Drive Replacement
Connor Thompson
Connor Thompson and 3 other contributors
Last updated on December 6, 2022
10 minutes
Easy
Introduction
Go to step 1
This is a simple guide on how to replace the CD Drive in the Toshiba Satellite C55-B5302 laptop. The part needed for the replacement can be found here. Be sure to have the proper tools as well as the necessary parts needed to complete this guide.
Tools
  1. Toshiba Satellite C55-B5302 CD Drive Replacement, CD Drive: step 1, image 1 of 1
    • Make sure to completely shut down the laptop using the power button.
  2. Toshiba Satellite C55-B5302 CD Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C55-B5302 CD Drive Replacement: step 2, image 2 of 2
    • Using the Phillips #1 screwdriver, unscrew the two 7mm screws near the battery.
  3. Toshiba Satellite C55-B5302 CD Drive Replacement: step 3, image 1 of 2 Toshiba Satellite C55-B5302 CD Drive Replacement: step 3, image 2 of 2
    • Pull on the battery to remove it from the laptop.
  4. Toshiba Satellite C55-B5302 CD Drive Replacement: step 4, image 1 of 2 Toshiba Satellite C55-B5302 CD Drive Replacement: step 4, image 2 of 2
    • Using the Phillips #1 screwdriver, unscrew the 7mm middle screw.
  5. Toshiba Satellite C55-B5302 CD Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C55-B5302 CD Drive Replacement: step 5, image 2 of 2
    • Pull on the CD Drive to remove it from the laptop.
Connor Thompson
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 209
