Toshiba Satellite C55-B5302 Screen Bezel Replacement
  1. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Battery: step 1, image 2 of 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 2, image 1 of 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 3, image 1 of 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: step 4, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: step 4, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Fan: step 4, image 3 of 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 5, image 1 of 1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 6, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 6, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 6, image 3 of 3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 7, image 1 of 1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: step 8, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: step 8, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement, Screen Bezel: step 8, image 3 of 3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 9, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 9, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 9, image 3 of 3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 10, image 1 of 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 10, image 2 of 2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 11, image 1 of 2 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 11, image 2 of 2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 12, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 12, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 12, image 3 of 3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 13, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 13, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 13, image 3 of 3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 14, image 1 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 14, image 2 of 3 Toshiba Satellite C55-B5302 Screen Bezel Replacement: step 14, image 3 of 3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
David Browning
310 Reputation
2 Guides authored
IUPUI, Team S1-G3, Henning Spring 2019 Member of IUPUI, Team S1-G3, Henning Spring 2019
IUPUI-HENNING-S19S1G3
4 Members
6 Guides authored
2 Comments
Sir how will I find screen strip of toshiba c55-b1326
Shahid Iqbal - Reply
Sir how can I find screen strip of toshiba c55-b1326
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 587
