Toshiba Satellite C55-B5302 Webcam Replacement
David Browning
David Browning and 4 other contributors
Last updated on May 7, 2024
20 - 45 minutes
Difficult
Introduction
Go to step 1
These are the steps for removing the webcam from your Toshiba Satellite C55-B5302 laptop. Since the webcam is delicate in nature and has photosensitive parts, you should be careful when handling the webcam unit and make sure not to scratch the lens or expose it to bright light for too long.
Tools
Show more…
  1. Toshiba Satellite C55-B5302 Webcam Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement, Battery: step 1, image 2 of 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Webcam Replacement: step 2, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Webcam Replacement: step 3, image 1 of 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: step 4, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: step 4, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: step 4, image 3 of 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Webcam Replacement: step 5, image 1 of 1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Webcam Replacement: step 6, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 6, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 6, image 3 of 3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Webcam Replacement: step 7, image 1 of 1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: step 8, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: step 8, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: step 8, image 3 of 3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Webcam Replacement: step 9, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 9, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 9, image 3 of 3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Webcam Replacement: step 10, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement: step 10, image 2 of 2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Webcam Replacement: step 11, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement: step 11, image 2 of 2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Webcam Replacement: step 12, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 12, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 12, image 3 of 3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Webcam Replacement: step 13, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 13, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 13, image 3 of 3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Webcam Replacement: step 14, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 14, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 14, image 3 of 3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: step 15, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: step 15, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: step 15, image 3 of 3
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Webcam Replacement: step 16, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement: step 16, image 2 of 2
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Webcam Replacement: step 17, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 17, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 17, image 3 of 3
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Webcam Replacement: step 18, image 1 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 18, image 2 of 3 Toshiba Satellite C55-B5302 Webcam Replacement: step 18, image 3 of 3
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Webcam Replacement: step 19, image 1 of 2 Toshiba Satellite C55-B5302 Webcam Replacement: step 19, image 2 of 2
    Tool used on this step:
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
2 other people completed this guide.
David Browning
310 Reputation
2 Guides authored
IUPUI, Team S1-G3, Henning Spring 2019 Member of IUPUI, Team S1-G3, Henning Spring 2019
IUPUI-HENNING-S19S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 27
All Time: 1,681
