Toshiba Satellite C55-C5240  RAM Replacement
Angela Rodriguez
Angela Rodriguez and 2 other contributors
Last updated on November 12, 2023
5 - 10 minutes
Moderate
Introduction
Go to step 1
This is a guide that will assist you with replacing your RAM in a Toshiba Satellite C55-C5240.
Tools
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: step 1, image 3 of 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: step 2, image 1 of 3 Toshiba Satellite C55-C5240  RAM Replacement: step 2, image 2 of 3 Toshiba Satellite C55-C5240  RAM Replacement: step 2, image 3 of 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: step 3, image 1 of 2 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: step 3, image 2 of 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: step 4, image 1 of 3 Toshiba Satellite C55-C5240  RAM Replacement: step 4, image 2 of 3 Toshiba Satellite C55-C5240  RAM Replacement: step 4, image 3 of 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: step 5, image 1 of 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: step 5, image 2 of 3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: step 5, image 3 of 3
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: step 6, image 1 of 1
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
Angela Rodriguez
261 Reputation
2 Guides authored
USF Tampa, Team S1-G5, Nance Spring 2017 Member of USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,593
