Toshiba Satellite C55-C5240 Hard Drive Replacement
Abdel Feliciano Gonzalez
Abdel Feliciano Gonzalez and one other contributor
Last updated on November 12, 2023
5 - 10 minutes
Moderate
Featured Student Guide
Introduction
Go to step 1
Whether or not you are upgrading your storage or the hard drive is out of commission, this guide will help you remove it.
Tools
  1. Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Hard Drive Replacement: step 2, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 2, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 2, image 3 of 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: step 3, image 1 of 2 Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: step 3, image 2 of 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Hard Drive Replacement: step 4, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 4, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 4, image 3 of 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: step 5, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: step 5, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: step 5, image 3 of 3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Hard Drive Replacement: step 6, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 6, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 6, image 3 of 3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Hard Drive Replacement: step 7, image 1 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 7, image 2 of 3 Toshiba Satellite C55-C5240 Hard Drive Replacement: step 7, image 3 of 3
    • Peel off the rubber hard drive mount.
5 other people completed this guide.
722 Reputation
4 Guides authored
USF Tampa, Team S1-G5, Nance Spring 2017 Member of USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 16
All Time: 1,785
