Toshiba Satellite C55-C5240 Screen Replacement
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: step 1, image 3 of 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: step 2, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 2, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 2, image 3 of 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: step 3, image 1 of 2 Toshiba Satellite C55-C5240 Screen Replacement, Back cover: step 3, image 2 of 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: step 4, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 4, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 4, image 3 of 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: step 5, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: step 5, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: step 5, image 3 of 3
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: step 6, image 1 of 1
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: step 7, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 7, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 7, image 3 of 3
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: step 8, image 1 of 2 Toshiba Satellite C55-C5240 Screen Replacement: step 8, image 2 of 2
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: step 9, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 9, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: step 10, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 10, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 10, image 3 of 3
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: step 11, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 11, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 11, image 3 of 3
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: step 12, image 1 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 12, image 2 of 3 Toshiba Satellite C55-C5240 Screen Replacement: step 12, image 3 of 3
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
4 other people completed this guide.
Angela Rodriguez
261 Reputation
2 Guides authored
USF Tampa, Team S1-G5, Nance Spring 2017 Member of USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,462
