Toshiba Satellite C55-C5268 Battery Replacement
Greg Smith
Greg Smith and 6 other contributors
Last updated on December 14, 2022
45 seconds
Easy
Introduction
Go to step 1
The battery of the Toshiba Satellite is located on the bottom of the laptop, near where the screen attaches to the base. It is held in place by two Phillips head screws which need to be removed in order to remove the battery. The iFixit toolkit size PH1 bit will fit.
Parts
Tools
Show more…
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: step 1, image 1 of 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: step 2, image 1 of 2 Toshiba Satellite C55-C5268 Battery Replacement: step 2, image 2 of 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
Greg Smith
347 Reputation
2 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2016 Member of UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Members
12 Guides authored
2 Comments
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - Reply
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - Reply
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 79
All Time: 17,767
