Toshiba Satellite C55D-B5206 Hard Drive Replacement
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 2, image 2 of 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: step 3, image 1 of 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 4, image 1 of 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 5, image 1 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 5, image 2 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 5, image 3 of 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 7, image 1 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 7, image 2 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 7, image 3 of 3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 8, image 1 of 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 8, image 2 of 2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 9, image 1 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 9, image 2 of 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: step 9, image 3 of 3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
7 other people completed this guide.
Michelle
175 Reputation
1 Guide authored
CSU Fullerton, Team 2-5, Bruce Fall 2015 Member of CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Members
18 Guides authored
2 Comments
Thanks.. Really helped out..
SpeedyBlanco - Reply
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 4,731
