Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: step 1, image 1 of 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: step 1, image 2 of 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: step 1, image 3 of 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 2, image 1 of 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 3, image 1 of 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 3, image 2 of 2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 4, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 5, image 1 of 1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 6, image 1 of 1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 7, image 1 of 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: step 7, image 2 of 2
    • Pull the fan and heat sink away from the motherboard.
Laura Tamayo
678 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2019 Member of USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 Members
10 Guides authored
One Comment
My Toshiba laptop shut down exactly after 30 minutes why is the reason? Please tell me the problem & the solution.
Afetes - Reply
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 23
All Time: 401
