Toshiba Satellite C55D-C5106 Disk Drive Replacement
  1. Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: step 1, image 1 of 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: step 1, image 2 of 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: step 1, image 3 of 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 2, image 1 of 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 3, image 1 of 1
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
  4. Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 4, image 1 of 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 4, image 2 of 3 Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 4, image 3 of 3
    • Use the metal spudger to remove the bottom cover of the laptop.
  5. Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C55D-C5106 Disk Drive Replacement: step 5, image 2 of 2
    • Remove the disk drive by gently pulling it up and sliding it out.
Laura Tamayo
678 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2019 Member of USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 24
All Time: 357
