Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement
  1. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, Back Cover: step 1, image 1 of 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  2. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 2, image 1 of 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  3. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 3, image 1 of 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 4, image 1 of 2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 4, image 2 of 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  5. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, DC Power Jack: step 5, image 1 of 2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement, DC Power Jack: step 5, image 2 of 2
    • Remove the DC power jack from its plastic retaining piece, just inside of the charger inlet.
  6. Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 6, image 1 of 2 Toshiba Satellite C55Dt-A5306 DC Power Jack Replacement: step 6, image 2 of 2
    • Use the nylon spudger to remove the connecting wires from the motherboard. Insert the spudger between the terminal plastic piece of the wire and its retaining clip on the mother board. The wire should release without much force.
Patrick Kroenung
122 Reputation
1 Guide authored
One Comment
I got a power jack from seller dcincable.com, it's exactly the same as your images show, but I could not find a service manual, it's great to have your help, thank you so much.
Tom - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 816
