Toshiba Satellite C55Dt-A5306 Disc Drive Replacement
  1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Battery: step 1, image 1 of 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: step 2, image 1 of 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Back Cover: step 3, image 1 of 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: step 4, image 1 of 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: step 5, image 1 of 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: step 6, image 1 of 2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: step 6, image 2 of 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: step 7, image 1 of 2 Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: step 7, image 2 of 2
    • Slide the disc drive to the left. It should come off with ease.
zeena qiryaqoz
301 Reputation
3 Guides authored
One Comment
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
ed_l_grey - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 437
