Toshiba Satellite C655D-S5084 Hard Drive Replacement
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: step 3, image 1 of 1
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: step 4, image 1 of 1
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
4 other people completed this guide.
Shelby Kunz
69 Reputation
5 Guides authored
Cal Poly, Team 2-20, Maness Spring 2013 Member of Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 3,403
