Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): step 1, image 1 of 2 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): step 1, image 2 of 2
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: step 2, image 1 of 1
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: step 3, image 1 of 1
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
3 other people completed this guide.
Shelby Kunz
69 Reputation
5 Guides authored
Cal Poly, Team 2-20, Maness Spring 2013 Member of Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 22
All Time: 3,126
