Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
Video Overview
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: step 1, image 1 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: step 1, image 2 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: step 1, image 3 of 3
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 2, image 1 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 2, image 2 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 2, image 3 of 3
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 3, image 1 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 3, image 2 of 3 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 3, image 3 of 3
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 4, image 1 of 2 Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: step 4, image 2 of 2
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
5 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
3 Comments
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - Reply
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 73
All Time: 8,267
