Toshiba Satellite C855-S5115 CMOS Battery Replacement
  1. Toshiba Satellite C855-S5115 CMOS Battery Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855-S5115 CMOS Battery Replacement, Battery: step 1, image 2 of 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 CMOS Battery Replacement: step 2, image 1 of 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 CMOS Battery Replacement, CMOS Battery: step 3, image 1 of 1
    • Remove the 7mm screw from the back panel using the Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 CMOS Battery Replacement: step 4, image 1 of 2 Toshiba Satellite C855-S5115 CMOS Battery Replacement: step 4, image 2 of 2
    • Use the spudger to pry the back panel out of the laptop.
  5. Toshiba Satellite C855-S5115 CMOS Battery Replacement: step 5, image 1 of 2 Toshiba Satellite C855-S5115 CMOS Battery Replacement: step 5, image 2 of 2
    • Push the pin that holds the CMOS battery in place downwards. The battery will then come out.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 98
All Time: 5,441
