Toshiba Satellite C855-S5115 Cooling Fan Replacement
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: step 1, image 2 of 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 2, image 1 of 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 4, image 1 of 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 4, image 2 of 2
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 5, image 1 of 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 5, image 2 of 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 5, image 3 of 3
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 6, image 1 of 1
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 7, image 1 of 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 7, image 2 of 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 7, image 3 of 3
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 8, image 1 of 1
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 9, image 1 of 1
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 10, image 1 of 1
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 11, image 1 of 1
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 12, image 1 of 1
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: step 13, image 1 of 1
    • Remove the CPU fan.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,494
