Toshiba Satellite C855-S5115 Keyboard Replacement
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: step 2, image 1 of 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: step 3, image 1 of 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite C855-S5115 Keyboard Replacement: step 4, image 2 of 2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite C855-S5115 Keyboard Replacement: step 5, image 2 of 2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
2 Comments
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Reply
Do you have to do anything with the connector before removing?
William - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 2,578
