Toshiba Satellite C855-S5115 RAM Replacement
Claire Fletcher
Claire Fletcher and 2 other contributors
Last updated on December 29, 2022
7 - 10 minutes
Easy
Introduction
Go to step 1
If your device has slowed down or no longer has saving capacity, it's time for an upgrade. This guide will show you how to replace your RAM (Random Access Memory) when you need to expand your device's memory space.
Parts
Tools
Show more…
  1. Toshiba Satellite C855-S5115 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855-S5115 RAM Replacement, Battery: step 1, image 2 of 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 RAM Replacement: step 2, image 1 of 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 RAM Replacement, RAM: step 3, image 1 of 3 Toshiba Satellite C855-S5115 RAM Replacement, RAM: step 3, image 2 of 3 Toshiba Satellite C855-S5115 RAM Replacement, RAM: step 3, image 3 of 3
    • Remove the single 7mm Phillips screw holding the panel in place using the J1S screwdriver.
    • Remove the back panel using the opening tool.
  4. Toshiba Satellite C855-S5115 RAM Replacement: step 4, image 1 of 1
    • Gently push the metal hinges outwards from the RAM.
  5. Toshiba Satellite C855-S5115 RAM Replacement: step 5, image 1 of 1
    • Pull the RAM out from the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 31
All Time: 819
