Toshiba Satellite E45-B4100 Battery Replacement Replacement
  1. Toshiba Satellite E45-B4100 Battery Replacement Replacement, Battery Replacement: step 1, image 1 of 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Battery Replacement Replacement: step 2, image 1 of 1
    • Gently pull out the battery.
Tori Ryals
41 Reputation
2 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2016 Member of USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Members
10 Guides authored
2 Comments
You don't need to remove all the screws - only the two that are directly above the battery compartment. Tried it myself!
Patrick Lenny - Reply
Tengo una duda, es unicamente esta bateria la que hay que reemplazar o existe alguna bateria interna que tambien se daba reemplazar?
Nicolas del Castillo - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,872
