Toshiba Satellite E45-B4100 Cooling Fan Replacement
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: step 1, image 1 of 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 2, image 1 of 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 4, image 1 of 2 Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Pro Tech Toolkit
    $74.95
    Buy
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 5, image 1 of 1
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 6, image 1 of 1
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: step 7, image 1 of 1
    • Remove the attachment from the Processor by gently rotating and lifting.
Brendan Sweeney
182 Reputation
2 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2016 Member of USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 610
