Toshiba Satellite E45-B4100 Hard Drive Replacement
  1. Toshiba Satellite E45-B4100 Hard Drive Replacement, Battery Replacement: step 1, image 1 of 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 2, image 1 of 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 4, image 1 of 2 Toshiba Satellite E45-B4100 Hard Drive Replacement: step 4, image 2 of 2
    Tool used on this step:
    Pro Tech Toolkit
    $74.95
    Buy
    • Be sure to use ESD-safe tools, we recommend using the iFixit Pro Tech Toolkit
  5. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite E45-B4100 Hard Drive Replacement: step 5, image 2 of 2
    • Unplug the Hard Drive from the Motherboard.
  6. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 6, image 1 of 2 Toshiba Satellite E45-B4100 Hard Drive Replacement: step 6, image 2 of 2
    • Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
  7. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 7, image 1 of 2 Toshiba Satellite E45-B4100 Hard Drive Replacement: step 7, image 2 of 2
    • Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
    • Remove the USB Port Circuit Board.
  8. Toshiba Satellite E45-B4100 Hard Drive Replacement: step 8, image 1 of 2 Toshiba Satellite E45-B4100 Hard Drive Replacement: step 8, image 2 of 2
    • Gently remove the hard drive.
4 other people completed this guide.
Delaney
104 Reputation
1 Guide authored
USF Tampa, Team 1-4, Leahy Fall 2016 Member of USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Members
10 Guides authored
One Comment
By and large this and the B4200 guide are interchangeable. I followed both when reviving my B4100, as the pictures the respective authors show the components from different angle. Good stuff; thank you!
Kntai - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,430
