Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement
  1. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, Battery Replacement: step 1, image 1 of 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: step 2, image 1 of 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: step 3, image 1 of 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: step 3, image 2 of 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: step 3, image 3 of 3
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend the iFixit toolkit.
  4. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: step 4, image 1 of 1
    • Using the #0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive and remove the USB Port Circuit Board as shown.
Tori Ryals
41 Reputation
2 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2016 Member of USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 412
