Toshiba Satellite E45DW-C4210 Battery Replacement
  1. Toshiba Satellite E45DW-C4210  Battery  Replacement, Battery: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, remove all nine of the screws along the outside of the bottom of the laptop.
  2. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 1 of 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 2 of 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 3 of 3
    • Using your fingers, gently loosen the outside edge of the laptop.
    • Unsnap the bottom of the case from the computer by pulling each side apart in the middle of the computer.
  3. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 3, image 1 of 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 3, image 2 of 2
    • Pull up the black strip of tape.
  4. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 4, image 1 of 1
    • Using your pointer finger and thumb grab the cords where they connect to the plug.
    • Gently pull the battery attachment from the laptop.
  5. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 5, image 1 of 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 5, image 2 of 2
    • Using the Phillips #0 screwdriver, unscrew each of the four screws holding the battery in place.
  6. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 6, image 1 of 1
    • Lift and remove the battery from the device.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,034
