Toshiba Satellite E45T-A4300 Heat Sink  Replacement
James Nguyen
James Nguyen and 2 other contributors
Last updated on January 7, 2023
10 - 15 minutes
Moderate
Introduction
Go to step 1
The heat sink, along with the fan, helps keep the laptop from overheating. If the heat sink is damaged through be clogged that can’t be removed by the fan or cleaning, then a replacement is necessary to prolong the life and durability of the laptop.
Tools
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Heat Sink: step 3, image 1 of 1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 1 of 3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 2 of 3 Toshiba Satellite E45T-A4300 Heat Sink  Replacement: step 4, image 3 of 3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
James Nguyen
573 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 257
