Toshiba Satellite E45T-A4300 SSD Replacement Guide
James Nguyen
James Nguyen and one other contributor
Last updated on January 7, 2023
5 - 7 minutes
Easy
Introduction
Go to step 1
The solid state drive, or SSD in short, has the same functionality of the hard drive in storing data, but without a magnet. If the SSD is damaged from long time use or being given the wrong data, then a replacement for the SSD may be necessary.
Tools
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite E45T-A4300 SSD Replacement Guide, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 SSD Replacement Guide: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 SSD Replacement Guide, SSD: step 3, image 1 of 2 Toshiba Satellite E45T-A4300 SSD Replacement Guide, SSD: step 3, image 2 of 2
    • Remove the single 3 mm black screw using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 SSD Replacement Guide: step 4, image 1 of 1
    • Pull the SSD away from the motherboard.
James Nguyen
573 Reputation
5 Guides authored
One Comment
cual es el modelo del SSD
Victor A. Enriquez C. - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 11
All Time: 1,162
