Toshiba Satellite L15W-B1320 Battery Replacement
Elizabeth Zapata
Elizabeth Zapata and 2 other contributors
Last updated on January 18, 2023
10 minutes
Easy
Introduction
Go to step 1
The battery in a laptop can die due to a number of reasons like age, usage, and heat. This guide will show you how to replace the battery in the Toshiba Satellite L15W-B1320.
Tools
  1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite L15W-B1320 Battery Replacement, Battery: step 1, image 3 of 3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Battery Replacement: step 2, image 1 of 3 Toshiba Satellite L15W-B1320 Battery Replacement: step 2, image 2 of 3 Toshiba Satellite L15W-B1320 Battery Replacement: step 2, image 3 of 3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
Elizabeth Zapata
190 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,337
