Toshiba Satellite L305-S5946 Hard Drive Replacement
  1. Toshiba Satellite L305-S5946 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Hard Drive Replacement: step 2, image 1 of 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: step 3, image 3 of 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite L305-S5946 Hard Drive Replacement: step 5, image 2 of 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Hard Drive Replacement: step 6, image 1 of 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: step 6, image 2 of 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: step 6, image 3 of 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
4 other people completed this guide.
Alec
352 Reputation
1 Guide authored
Cal Poly, Team 3-49, Amido Spring 2013 Member of Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 2,133
