Toshiba Satellite L305-S5946 RAM Replacement
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: step 2, image 1 of 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite L305-S5946 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite L305-S5946 RAM Replacement: step 3, image 3 of 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: step 4, image 1 of 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: step 5, image 1 of 2 Toshiba Satellite L305-S5946 RAM Replacement: step 5, image 2 of 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: step 6, image 1 of 2 Toshiba Satellite L305-S5946 RAM Replacement: step 6, image 2 of 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: step 7, image 1 of 2 Toshiba Satellite L305-S5946 RAM Replacement: step 7, image 2 of 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Michael Erberich
133 Reputation
9 Guides authored
Cal Poly, Team 3-49, Amido Spring 2013 Member of Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Members
19 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 856
